Ga door naar hoofdinhoud
Dell Inspiron 6000 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 6000 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 6000 Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 6000 Keyboard Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 6000 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Gently pull the blue tab up until it comes away from computer.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jacob DeWar
533 Reputatie
3 handleidingen geschreven
USF Tampa, Team 11-1, Blackwell Fall 2014 Lid van USF Tampa, Team 11-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G1
5 Leden
7 handleidingen geschreven
Één opmerking
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 2,077
