Ga door naar hoofdinhoud
Dell Inspiron 5675 CMOS Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 5675 CMOS Battery Replacement, CMOS Battery: stap 1, afbeelding 3 van 3
    • Ensure the PC is a dell inspiron 5675.
  2. Dell Inspiron 5675 CMOS Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 5675 CMOS Battery Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the two screws on the side panel using your screwdriver.
  3. Dell Inspiron 5675 CMOS Battery Replacement: stap 3, afbeelding 1 van 1
    • Pull out the side panel using the handle.
  4. Dell Inspiron 5675 CMOS Battery Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 4, afbeelding 3 van 3
    • The CMOS battery is located on the motherboard, just below the M.2 SATA SSD slot. Use your thumb and nail to pull out the battery from its slot.
  5. Dell Inspiron 5675 CMOS Battery Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 5, afbeelding 3 van 3
    • After it's removed, grab the replacement battery.
    • Slide half the battery in the slot and use your thumb to push it down.
    • Once you hear a click or see its in place, it has been replaced.
  6. Dell Inspiron 5675 CMOS Battery Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 5675 CMOS Battery Replacement: stap 6, afbeelding 3 van 3
    • Grab the side panel and make sure the hooks match with their corresponding slots.
    • Push the side panel forward and screw the two screws back. (refer to step 2)
  7. Dell Inspiron 5675 CMOS Battery Replacement: stap 7, afbeelding 1 van 1
    • Replacement has been complete.
Eindstreep
Stefan Ciausu
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 37
Altijd: 845
