Inleiding
This guide will demonstrate removing the computer's CD/DVD drive.
Onderdelen
Geen onderdelen nodig.
  1. Place the case on its side.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Slide the side panel towards the back and remove.
    • Slide the side panel towards the back and remove.
    • Locate the CD/DVD drive in the upper-front corner of the case.
    • Locate and remove the two cables attached to the CD/DVD drive.
    • Locate and remove the two Phillips #0 7.8 mm screws.
    • Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Gently lift the three tabs to pull off the faceplate.
    • Pull the faceplate forward and out.
    • Completely remove the faceplate.
    • Remove the CD/DVD drive by pulling it forward towards the front.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Doug Howe
1.513 Reputatie
2 handleidingen geschreven
Cal Poly, Team 6-8, Regan Fall 2011 Lid van Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Leden
16 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 23
Afgelopen 30 Dagen: 64
Altijd: 14,109
