Ga door naar hoofdinhoud
Dell Inspiron 5100 PP07L Memory Replacement
Wat je nodig hebt
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: stap 1, afbeelding 1 van 1
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: stap 2, afbeelding 1 van 1
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: stap 3, afbeelding 1 van 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: stap 3, afbeelding 2 van 3 Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: stap 3, afbeelding 3 van 3
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Conclusie
May Chauvin
201 Reputatie
6 handleidingen geschreven
Cal Poly, Team 12-34, Maness Spring 2011 Lid van Cal Poly, Team 12-34, Maness Spring 2011
CPSU-MANESS-S11S12G34
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 4,486
