Ga door naar hoofdinhoud
Dell Inspiron 3847 RAM Stick Replacement
Wat je nodig hebt
  1. Dell Inspiron 3847 RAM Stick Replacement, RAM Stick: stap 1, afbeelding 1 van 1
    • Shut off and power down the PC by turning the switch to the off position, located on the back of the PC.
    • Unplug the power cable and remove any and all peripherals connected to PC.
  2. Dell Inspiron 3847 RAM Stick Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 2, afbeelding 3 van 3
    • Lay your PC flat on its side with the 'Inspiron' Logo facing up.
    • Remove the two Phillips #0 screws from the back side of panel.
    • Slide the side panel off completely.
  3. Dell Inspiron 3847 RAM Stick Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3847 RAM Stick Replacement: stap 3, afbeelding 2 van 2
    • Gently press down the flaps located on each end of the RAM slots. Remove the RAM stick(s) from the motherboard.
    • Repeat this step for each stick of RAM.
    • The flaps may be stiff when pressing down. Be careful not to use too much force if the RAM stick doesn't come loose.
  4. Dell Inspiron 3847 RAM Stick Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 4, afbeelding 3 van 3
    • Align the new memory sticks with the memory slots.
    • Gently press down until a “CLICK” sound is made and flaps are pointing upwards.
    • Repeat this step for each stick of RAM you want to install.
  5. Dell Inspiron 3847 RAM Stick Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 3847 RAM Stick Replacement: stap 5, afbeelding 3 van 3
    • Slide the side panel back into position and screw in with the same screws from Step #2.
    • Plug all peripherals into the PC and switch it back on.
    • Boot up the computer. If no errors appear, then installation is complete!
Conclusie
To check if your RAM is installed correctly, Right-click on My PC, Click Properties, and check Installed Memory under the System heading.
Maninder
171 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 53
Altijd: 1,027
