Ga door naar hoofdinhoud
Dell Inspiron 3542 Heat Sink Replacement
Wat je nodig hebt
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: stap 1, afbeelding 1 van 2 Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: stap 1, afbeelding 2 van 2
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 3542 Heat Sink Replacement: stap 2, afbeelding 2 van 2
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 3, afbeelding 3 van 3
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 4, afbeelding 3 van 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 5, afbeelding 3 van 3
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 3542 Heat Sink Replacement: stap 6, afbeelding 2 van 2
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 7, afbeelding 3 van 3
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: stap 8, afbeelding 1 van 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: stap 10, afbeelding 1 van 1
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: stap 11, afbeelding 1 van 2 Dell Inspiron 3542 Heat Sink Replacement: stap 11, afbeelding 2 van 2
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: stap 12, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 12, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 12, afbeelding 3 van 3
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: stap 13, afbeelding 1 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 13, afbeelding 2 van 3 Dell Inspiron 3542 Heat Sink Replacement: stap 13, afbeelding 3 van 3
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Rachel lindsey
718 Reputatie
5 handleidingen geschreven
Texas Tech, Team S46-G1, Bennett Spring 2017 Lid van Texas Tech, Team S46-G1, Bennett Spring 2017
TTU-BENNETT-S17S46G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 1,366
