Ga door naar hoofdinhoud
Dell Inspiron 3520 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 3520 RAM Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 3520 RAM Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 RAM Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 3520 RAM Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 3520 RAM Replacement: stap 2, afbeelding 3 van 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 RAM Replacement, Keyboard: stap 3, afbeelding 1 van 2 Dell Inspiron 3520 RAM Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 RAM Replacement: stap 4, afbeelding 1 van 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 RAM Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 3520 RAM Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
  6. Dell Inspiron 3520 RAM Replacement, RAM: stap 6, afbeelding 1 van 1
    • Locate the RAM chip(s)
    • There are no RAM chips present in this photo.
  7. Dell Inspiron 3520 RAM Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 3520 RAM Replacement: stap 7, afbeelding 2 van 2
    • There are two connecting pins for the lower chip.
    • There are two connecting pins for the upper chip.
    • Pull the pins away from the sides of the chip(s) to release it.
    • The chip(s) should slide away from the dock easily.
Conclusie
17 andere personen hebben deze handleiding voltooid.
Ian
1.557 Reputatie
5 handleidingen geschreven
USF Tampa, Team 16-2, Watkins Winter 2015 Lid van USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 69
Altijd: 32,646
