Ga door naar hoofdinhoud
Dell Inspiron 3148 WLAN Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 3148 WLAN Card Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3148 WLAN Card Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: stap 4, afbeelding 1 van 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: stap 4, afbeelding 2 van 3 Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: stap 4, afbeelding 3 van 3
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: stap 5, afbeelding 1 van 1
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 3148 WLAN Card Replacement: stap 6, afbeelding 2 van 2
    • Using your fingers, pull the WLAN card up and away from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Gravelle
837 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 266
