Ga door naar hoofdinhoud
Dell Inspiron 3148 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 3148 RAM Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 3148 RAM Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 RAM Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 RAM Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3148 RAM Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 RAM Replacement, RAM: stap 4, afbeelding 1 van 1
    • Locate the RAM chips on the motherboard.
  5. Dell Inspiron 3148 RAM Replacement: stap 5, afbeelding 1 van 1
    • There are two tabs on either side of the RAM chip. Pull them away from the chip.
  6. Dell Inspiron 3148 RAM Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 3148 RAM Replacement: stap 6, afbeelding 2 van 2
    • The RAM chip will pop up out of the slot.
    • Pinch the RAM between two fingers, making minimal contact. Gently pull away from its port.
    • Remove the RAM from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Gravelle
837 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 295
