Ga door naar hoofdinhoud
Dell Inspiron 3148 Fan Replacement
Wat je nodig hebt
  1. Dell Inspiron 3148 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 3148 Fan Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Fan Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Fan Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3148 Fan Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Fan Replacement, Fan: stap 4, afbeelding 1 van 3 Dell Inspiron 3148 Fan Replacement, Fan: stap 4, afbeelding 2 van 3 Dell Inspiron 3148 Fan Replacement, Fan: stap 4, afbeelding 3 van 3
    • If there is tape on your fan, remove the tape.
    • Remove the two 2mm screws on the fan enclosure using the Phillips #00 screwdriver.
  5. Dell Inspiron 3148 Fan Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 3148 Fan Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the three 4mm screws holding down the heat sink of the fan using the Phillips #00 screwdriver.
    • The three 4mm screws found in the heat sink will remain attached to the heat sink. This is okay as long as they are detached from the motherboard.
  6. Dell Inspiron 3148 Fan Replacement: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to gently pull the power supply cable from its port.
  7. Dell Inspiron 3148 Fan Replacement: stap 7, afbeelding 1 van 1
    • Grasp the fan and lift upward. Remove the fan from the device.
Conclusie
Christopher Gravelle
837 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 165
