Ga door naar hoofdinhoud
Dell Inspiron 3148 Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 3148 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 3148 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Battery Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3148 Battery Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Battery Replacement: stap 5, afbeelding 1 van 1
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Battery Replacement: stap 6, afbeelding 1 van 1
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the battery completely.
Conclusie
Christopher Gravelle
837 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Leden
Één opmerking
Apparently the battery screws on mine all have red thread lock on them, meaning they will not come out and I fear I may end up stripping them if I’m not careful, I got one out, which his how I know they used red thread lock. Blue would have been sufficient
Joshua Vignolo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 300
