Ga door naar hoofdinhoud
Dell Inspiron 3148 Back Panel Replacement
Wat je nodig hebt
  1. Dell Inspiron 3148 Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 3148 Back Panel Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Back Panel Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 3148 Back Panel Replacement: stap 3, afbeelding 2 van 2
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
Conclusie
Christopher Gravelle
837 Reputatie
7 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 Lid van UMass Dartmouth, Team S1-G2, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 18
Altijd: 264
