Ga door naar hoofdinhoud
Dell Inspiron 17R-N7110 DC Power Jack Replacement
Wat je nodig hebt
  1. Dell Inspiron 17R-N7110 DC Power Jack Replacement, Battery: stap 1, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement, Battery: stap 1, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement, Battery: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 2, afbeelding 2 van 2
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. Dell Inspiron 17R-N7110 DC Power Jack Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Do not pull the keyboard away from the laptop. The keyboard is connected to the motherboard by a cable. Pulling the keyboard may cause damage to the keyboard and/or motherboard.
    • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy was the only tool to work.
    • Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
    • Tilt the metal jimmy away from you to pry up the edge of the keyboard.
    • Repeat the previous actions on each of the other three holes to release the keyboard.
  4. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 4, afbeelding 2 van 2
    • Gently flip the keyboard over and lay it on the touchpad area.
  5. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 5, afbeelding 3 van 3
    • Flip up the black flap where the keyboard cable connects to the motherboard
    • Gently pull the cable away from the slot to release the keyboard.
    • Remove the keyboard from the device.
  6. Dell Inspiron 17R-N7110 DC Power Jack Replacement, DC Power Jack: stap 6, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement, DC Power Jack: stap 6, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the 5mm screws from the bottom. There are a total of 15 screws.
  7. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 7, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to unscrew the four 5mm screws from the palmrest.
    • Flip up the black flap over the first cable.
    • Gently pull the cable away from the tab to remove it.
    • Repeat for the other two cables pictured.
  8. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 8, afbeelding 2 van 2
    • Do not proceed without holding the laptop screen/lid for support. The screen is very heavy and may cause the device to fall if not held and supported.
    • Use a plastic opening tool to pry up the edges of the palmrest cover.
    • Gently lift up the palmrest cover.
  9. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 9, afbeelding 3 van 3
    • Gently pull the cooling fan cable horizontally to unplug it.
    • Use a Phillips #0 screwdriver to remove the two 5mm screws from the cooling fan.
    • Lift the top right corner of the fan and pull up and to the right.
  10. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 10, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 10, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 10, afbeelding 3 van 3
    • Flip up the flap over the first cable pictured and then gently pull the cable to remove it.
    • Use your finger to pull up the yellow tape and unplug the webcam cable.
    • Unplug the DC power jack cable.
  11. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 11, afbeelding 1 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 11, afbeelding 2 van 3 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 11, afbeelding 3 van 3
    • Lift the two cables with the gold ends connected to the I/O board to disconnect them.
    • Use a Phillips #0 screwdriver to unscrew the two 5mm screws from the right side of the screen base.
    • Use a Phillips #0 screwdriver to unscrew the two 5mm screws from the left side of the screen base.
  12. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 12, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 12, afbeelding 2 van 2
    • Gently hold the screen and pull it straight up to remove it.
    • Pry the plastic backing that is under the screen upward with your fingers to remove it.
  13. Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 17R-N7110 DC Power Jack Replacement: stap 13, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to unscrew the 5mm screw from the DC power jack base.
    • Pull the DC power jack cable towards you.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,886
