Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip over the laptop so the back is facing upwards.
Locate the battery compartment.
Slide both locks away from the center of the battery.
After you hear a click, pull out the battery.
Remove the four screws from the back panel.
Flip the laptop over and open it to view the keyboard.
Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
Close the laptop and flip it over so the bottom is facing upwards.
Remove the two screws from the small panel.
Remove the small back panel.
Slide the CD drive out of the laptop.
Remove the three screws from the CD drive slot.
Remove the top cover by inserting a spudger under the surface.
Working clockwise, pry upwards with the spudger to detach the clips.
Disconnect the ribbon cables.
Remove the cover to access the inner hardware of the laptop.
