Ga door naar hoofdinhoud
Dell Inspiron 17R-5721 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 17R-5721 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
    • This mechanically unlocks the battery pack from its slot at the back of the machine.
  2. Dell Inspiron 17R-5721 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 17R-5721 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using your fingernails, pry the battery pack away from the rest of the machine, at the physical seam between the pack and the laptop’s plastic case.
    • This may take some effort to accomplish.
    • Remove the battery.
  3. Dell Inspiron 17R-5721 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Open the laptop to reveal the keyboard.
    • Using a plastic opening tool, pry the keyboard free from the palmrest assembly at the plastic tabs located across the top of the keyboard.
  4. Dell Inspiron 17R-5721 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Once free from the palmrest, flip over the keyboard.
    • Unplug the ribbon cable connecting the keyboard to the motherboard.
    • Remove the keyboard.
Conclusie
Thomas Griffin
915 Reputatie
9 handleidingen geschreven
UMass Dartmouth, Team S2-G6, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G6, Bailey Spring 2019
UMASSD-BAILEY-S19S2G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 309
