Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
It is useful to replace or clean your fan if your laptop crashes due to overheating or is abnormally hot.
Wat je nodig hebt
Place the laptop on a flat stable surface.
Flip the laptop over so the underside is visible.
Remove the sixteen 2mm Phillips #00 screws from the bottom of the laptop.
Remove the two 2mm Phillips #0 screws from the hard drive port.
Flip the laptop over horizontally and open up the lid.
Insert the tip of the plastic opening tool into the upper left corner of the panel.
Keeping its tip under the top panel, slide the plastic opening tool around the panel until the panel is completely loose. Next gently remove the panel.
Remove the four 2mm Phillips #0 screws at the top of the keyboard.
Slide the plastic opening tool around the keyboard until the keyboard is completely loose. Gently remove the keyboard.
Gently remove the three grey wires from the metal tabs.
Insert the tip of the plastic opening tool into the bottom left corner of the panel.
Gently lift off the top metal panel.
Remove the seven 2mm Phillips #0 screws.
Remove the two 2mm Phillips #00 screws.
Lift the motherboard by its top end and remove it from the laptop.
Flip the motherboard over to reveal the fan.
Remove the five 1mm Phillips #00 captive screws from the internal fan.
Lift the fan away from the motherboard.
Refer to iFixit's guide for removal and cleaning of the thermal paste. Aanbrengen van koelpasta
7 andere personen hebben deze handleiding voltooid.
3 opmerkingen
I have one of these. Thank you for the explanation but what a godawfully messy laptop design. Taking apart the complete laptop to replace something basic as a FAN???
My next laptop will not be a Dell...
Cheers,
Rob.
