Ga door naar hoofdinhoud
Dell Inspiron 1721 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 1721 Display Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 Dell Inspiron 1721 Display Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: stap 2, afbeelding 1 van 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: stap 2, afbeelding 2 van 3 Dell Inspiron 1721 Display Assembly Replacement, Hinge Plate Cover: stap 2, afbeelding 3 van 3
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 Display Assembly Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 1721 Display Assembly Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: stap 4, afbeelding 1 van 2 Dell Inspiron 1721 Display Assembly Replacement, Display Assembly: stap 4, afbeelding 2 van 2
    • Loosen the two captive Phillips #0 screws.
    • Remove the cover.
  5. Dell Inspiron 1721 Display Assembly Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the antenna connectors from the WLAN card.
  6. Dell Inspiron 1721 Display Assembly Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 1721 Display Assembly Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 1721 Display Assembly Replacement: stap 6, afbeelding 3 van 3
    • Remove the 3mm Phillips #0 screw securing the connector to the case ground.
    • Disconnect the display connector.
    • Disconnect the second connector, then remove the cable from the base.
  7. Dell Inspiron 1721 Display Assembly Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 1721 Display Assembly Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 1721 Display Assembly Replacement: stap 7, afbeelding 3 van 3
    • Remove the display cable from the palm rest.
    • Use a spudger to carefully pull the antenna wires through to front of the device.
  8. Dell Inspiron 1721 Display Assembly Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 1721 Display Assembly Replacement: stap 8, afbeelding 2 van 2
    • Remove the two 3.5 mm Phillips screws that hold the display assembly in place.
    • Lift the assembly straight up to separate it from the body of the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 172
