Inleiding
A device with such large screen should most definitely come with nice speakers to go along with it!
Wat je nodig hebt
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Detach the cable that connects the speakers to the system board.
Starting with the speaker on the right hand area of the touch pad, carefully guide the speaker cabling out of the enclosure. You need only to lift upwards.
Bijna klaar!
Conclusie
