Ga door naar hoofdinhoud
Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: stap 1, afbeelding 1 van 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Base Cover: stap 1, afbeelding 2 van 2
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 2, afbeelding 2 van 2
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 3, afbeelding 3 van 3
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 4, afbeelding 3 van 3
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: stap 5, afbeelding 1 van 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement, Coin Cell (CMOS) Battery: stap 5, afbeelding 2 van 2
    • Disconnect the CMOS battery cable from the motherboard.
  6. Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 17" 7786 2-in-1 Coin Cell (CMOS) Battery Replacement: stap 6, afbeelding 2 van 2
    • The battery may have a very strong adhesive keeping it from peeling off easily.
    • Peel the battery off.
Conclusie
Delia Padilla
588 Reputatie
5 handleidingen geschreven
Gateway, Team 1-3, Class Fall 2022 Lid van Gateway, Team 1-3, Class Fall 2022
GCC-CLASS-F22S1G3
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 39
Altijd: 599
