Ga door naar hoofdinhoud
Dell Inspiron 17-7737 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 17-7737 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 RAM Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 17-7737 RAM Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 17-7737 RAM Replacement: stap 2, afbeelding 3 van 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 RAM Replacement: stap 3, afbeelding 1 van 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 RAM Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 17-7737 RAM Replacement: stap 4, afbeelding 2 van 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 RAM Replacement, RAM: stap 5, afbeelding 1 van 3 Dell Inspiron 17-7737 RAM Replacement, RAM: stap 5, afbeelding 2 van 3 Dell Inspiron 17-7737 RAM Replacement, RAM: stap 5, afbeelding 3 van 3
    • Pry the memory module's cover off of the computer's base using an opening tool.
  6. Dell Inspiron 17-7737 RAM Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 17-7737 RAM Replacement: stap 6, afbeelding 2 van 2
    • Remove the 1st stick of memory by pushing the two lock pins to the side and pulling the stick out of the base.
  7. Dell Inspiron 17-7737 RAM Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 17-7737 RAM Replacement: stap 7, afbeelding 2 van 2
    • Remove the second RAM stick in the same fashion.
Conclusie
Mark Batista
457 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 66
