Ga door naar hoofdinhoud
Dell Inspiron 17-7737 Hard Disk Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 2, afbeelding 3 van 3
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 4, afbeelding 2 van 2
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: stap 5, afbeelding 1 van 1
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 6, afbeelding 1 van 1
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 8, afbeelding 1 van 1
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: stap 9, afbeelding 1 van 1
    • Using the pull tab, lift the hard drive out of the cage.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mark Batista
457 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 Lid van UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G7
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 39
Altijd: 263
