Ga door naar hoofdinhoud
Dell Inspiron 17-5755 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 17-5755 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 17-5755 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Dell Inspiron 17-5755 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
  5. Dell Inspiron 17-5755 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Use a plastic opening tool to gently release the tabs that secure the keyboard to the laptop.
  6. Dell Inspiron 17-5755 Keyboard Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 17-5755 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Carefully lift the keyboard from the laptop, being mindful of any attachments that it may have.
  7. Dell Inspiron 17-5755 Keyboard Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 17-5755 Keyboard Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 17-5755 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Lift the zero insertion force (ZIF) tab that secures the keyboard back light ribbon cable
    • Afterwards, carefully detach the backlight cable from the laptop.
  8. Dell Inspiron 17-5755 Keyboard Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 17-5755 Keyboard Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 17-5755 Keyboard Replacement: stap 8, afbeelding 3 van 3
    • Gently release the ZIF tab that secures the keyboard ribbon cable to the laptop.
    • Afterwards, carefully slide the cable out of its slot.
  9. Dell Inspiron 17-5755 Keyboard Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 17-5755 Keyboard Replacement: stap 9, afbeelding 2 van 2
    • Now that the keyboard is detached from the laptop, you may safely remove it.
Conclusie
Gabriel Espinal
215 Reputatie
1 Handleiding geschreven
USF Tampa, Team S6-G1, Lacy Spring 2017 Lid van USF Tampa, Team S6-G1, Lacy Spring 2017
USFT-LACY-S17S6G1
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 16
Altijd: 741
