Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Remove the two 5.5mm screws that secure the base cover to the computer's base.
Using the plastic opening tool, carefully pry open the base cover starting from the center.
Lift the base cover upwards to remove and set it aside.
Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
Lift the hard-drive assembly off the computer base
Disconnect the antenna cables from the wireless card.
Push the securing tab to release the wireless card.
Slide the wireless card out of the wireless-card slot.
Turn the computer over and open the display as far as possible
Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
Remove the (5) 5.5mm screws that secure the palm rest to the system board.
Close the display and turn the computer over.
Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
Turn the computer over and open the display as far as possible.
Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
Lift the palm rest away from the display assembly.
Remove the 2.5mm screw that secures the optical-drive connector board to the computer base.
Move wireless card wires covering the board away from the board.
Slide the optical-drive connector board away from the computer base.
Lift the optical-drive connector board away from the computer base.
Remove the 5.5mm screws that secure the battery-connector board to the computer base.
Carefully lift the battery-connector board to disconnect it from the system board.
Remove the antenna cables from the routing guides on the computer base.
Slide the antenna cables through the slot on the computer base.
Peel off the tape that secures the display cable to the system-board assembly.
Lift the connector latch and disconnect the display cable from the system board.
Lift the connector latch and disconnect the I/O board cable from the system board.
Turn the system-board assembly over and place it on a flat and clean surface.
In sequential order (indicated on the heat sink), loosen the (3) captive 5.5mm screws that secure the heat-sink assembly to the system board.
Disconnect the fan cable from the system board.
Lift the heat-sink assembly off the system board.
