Wat je nodig hebt
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Turn off power to the laptop.
Unplug the charging cable from the laptop.
Remove the two 5.5mm screws that secure the base cover to the computer's base.
Using the plastic opening tool, carefully pry open the base cover starting from the center.
Lift the base cover upwards to remove and set it aside.
Remove the 2.5mm screw that secures the hard-drive assembly to the computer base.
Using the pull tab, slide the hard-drive assembly to disconnect it from the system board.
Lift the hard-drive assembly off the computer base
Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
Turn the computer over and open the display as far as possible
Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
Remove the (5) 5.5mm screws that secure the palm rest to the system board.
Close the display and turn the computer over.
Remove the (10) 5.5mm screws that secure the palm rest to the computer base.
Turn the computer over and open the display as far as possible.
Lift the connector latches and disconnect the power-button board cable and the touch-pad cable from the system board.
Using a plastic scribe, gently lift and release the tabs on the palm rest around the computer base including the backside.
Lift the palm rest away from the display assembly.
Remove the 5.5mm screws that secure the battery-connector board to the computer base.
Carefully lift the battery-connector board to disconnect it from the system board.
