Ga door naar hoofdinhoud
Dell Inspiron 16-7610 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 1 van 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 1 van 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement, Wi-Fi Card: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the screw that secures the Wi-Fi card bracket to the system board.
    • Lift the Wi-Fi card bracket off of the Wi-Fi card.
  4. Dell Inspiron 16-7610 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 16-7610 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to disconnect the coaxial cables from the Wi-Fi card.
    • Slide the Wi-Fi card from the slot to remove it from the device.
Conclusie
Tristan Fairweather
85 Reputatie
1 Handleiding geschreven
Gateway, Team 1-3, Pee Spring 2023 Lid van Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 161
