Ga door naar hoofdinhoud
Dell Inspiron 16-7610 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 16-7610 RAM Replacement, Back Case: stap 1, afbeelding 1 van 2 Dell Inspiron 16-7610 RAM Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 RAM Replacement: stap 2, afbeelding 1 van 1
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 RAM Replacement, RAM: stap 3, afbeelding 1 van 3 Dell Inspiron 16-7610 RAM Replacement, RAM: stap 3, afbeelding 2 van 3 Dell Inspiron 16-7610 RAM Replacement, RAM: stap 3, afbeelding 3 van 3
    • Flip the plastic cover over to reveal the RAM stick. Do not pull the plastic cover off.
    • Pull the two RAM retaining arms away from the center of the RAM stick.
    • The RAM stick should "pop" up slightly from its socket.
    • Pull the RAM stick out of the socket. Repeat for each of the RAM sticks you are replacing.
    • Align your new RAM sticks on to the sockets when installing them to prevent any damage to the pins below.
Conclusie
Michael Torres
145 Reputatie
2 handleidingen geschreven
Gateway, Team 1-3, Pee Spring 2023 Lid van Gateway, Team 1-3, Pee Spring 2023
GCC-PEE-S23S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 335
