Inleiding
In this guide, we will be showing you how to remove and replace the Hard Drive Assembly.
Wat je nodig hebt
Lift the hard-drive assembly to disconnect it from the system board and remove the hard-drive assembly from the computer base.
Remove the screws that secure the hard drive to the hard-drive bracket.
Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
Replace the screws that secure the hard drive to the hard-drive bracket.
Slide the hard-drive assembly toward the back of the computer, to connect the hard-drive assembly to the connector on the system board.
