Ga door naar hoofdinhoud
Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement
Wat je nodig hebt
  1. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: stap 1, afbeelding 1 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: stap 1, afbeelding 2 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement, AC/DC Power Jack Plug Socket: stap 1, afbeelding 3 van 3
    • Flip the laptop over with the bottom facing up.
    • Pull the latches away from each other to release the battery.
    • Remove the battery.
  2. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 2, afbeelding 2 van 2
    • Throughout this guide, be sure to keep all screws in a safe place so they do not get lost. You should also keep them organized so they do not get mixed up.
    • Remove the 4 screws in the battery compartment using a 2.0mm magnetic phillips head screwdriver.
  3. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 3, afbeelding 1 van 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 3, afbeelding 2 van 2
    • The screws do not come out of the access door. Do not try to remove them.
    • Loosen the 3 screws on the access door using the 2.0mm phillips head screwdriver.
    • Remove the access door.
  4. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 4, afbeelding 3 van 3
    • Remove the disk drive screw using the 2.0mm phillips head screwdriver.
    • Remove the disk drive from the laptop.
    • Remove the 2 screws under the disk drive with the 2.0mm phillips head screwdriver.
  5. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 5, afbeelding 2 van 2
    • Remove the 4 hard drive screws using the 2.0mm phillips head screwdriver.
    • Pull the tab to remove the hard drive from the computer.
  6. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 6, afbeelding 1 van 1
    • Remove the 5 bottom base screws using the 2.0mm phillips head screwdriver.
  7. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 7, afbeelding 3 van 3
    • Depress the keyboard latches to release the keyboard with the 2.0mm flat head screwdriver.
    • Lift the keyboard up carefully.
    • Release the two ribbon cables underneath the keyboard.
  8. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 8, afbeelding 1 van 2 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 8, afbeelding 2 van 2
    • Remove the 6 palm rest screws using the 2.0mm phillips head screwdriver.
    • Unplug the 3 ribbon cables.
  9. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 9, afbeelding 1 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 9, afbeelding 2 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 9, afbeelding 3 van 3
    • Take your time on this step and be careful to not break the plastic palm rest.
    • Separate the palm rest from the bottom base using the 2.0mm flat head screwdriver as a lever.
    • Unplug the ribbon cable underneath the palm rest.
  10. Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 10, afbeelding 1 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 10, afbeelding 2 van 3 Dell Inspiron 15r 7520 AC/DC Power Jack Plug Socket Replacement: stap 10, afbeelding 3 van 3
    • Remove the 2 DC jack bracket screws with the 2.0mm phillips head screwdriver and remove the bracket.
    • Unplug and remove the old DC jack.
Conclusie
Follow these instructions in reverse order to reassemble your device.
Allen Van Den Boom
109 Reputatie
1 Handleiding geschreven
Michigan Tech, Team S3-G1, Galliah Fall 2017 Lid van Michigan Tech, Team S3-G1, Galliah Fall 2017
MTU-GALLIAH-F17S3G1
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 1,443
