Ga door naar hoofdinhoud
Dell Inspiron 15R 5537 Wi-Fi Module Replacement
Wat je nodig hebt
  1. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before working inside your computer, read the safety information that shipped with your computer.
    • Close the display and turn over the computer to see the battery locking tabs.
  2. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 2, afbeelding 3 van 3
    • Pull both of the locking tabs outwards until they both click to release the battery.
    • Pull the battery out by lifting it from the top and sliding it forward.
  3. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Turn the laptop over so that the keyboard is facing up.
    • Use an opening tool to pry the keyboard from the base of the laptop.
    • Once the top of the keyboard is released, slide the keyboard upwards.
    • Be sure not to pull the keyboard straight up; this could damage the keyboard ribbon cable.
  4. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 4, afbeelding 3 van 3
    • Use an opening tool to remove the keyboard ribbon from the latch by lifting the tab on top.
    • Once lifted, disconnect the ribbon and replace with a new keyboard.
  5. Dell Inspiron 15R 5537 Wi-Fi Module Replacement, Wi-Fi Module: stap 5, afbeelding 1 van 1
    • Once the keyboard is removed, the Wi-Fi module will be accessible.
  6. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 6, afbeelding 1 van 2 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 6, afbeelding 2 van 2
    • Use the opening tool to lift both antenna cables upward from the Wi-Fi module.
  7. Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 15R 5537 Wi-Fi Module Replacement: stap 7, afbeelding 3 van 3
    • Remove the 3mm Phillips #000 screw securing the Wi-Fi module.
    • Lift the Wi-Fi module up and out of the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 30
Altijd: 943
