Ga door naar hoofdinhoud
Dell Inspiron 15R 5521 Display Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 15R 5521 Display Assembly Replacement, Peeling the Tape: stap 1, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Peel the tape that secures the display cable to the system board.
  2. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnecting the Display Cable: stap 2, afbeelding 1 van 1
    • Disconnect the display cable from the connectors on the system board.
  3. Dell Inspiron 15R 5521 Display Assembly Replacement, Disconnect the Cables: stap 3, afbeelding 1 van 1
    • Disconnect the wireless mini-card cables from the connectors on the wireless mini-card.
  4. Dell Inspiron 15R 5521 Display Assembly Replacement, Moving the Port Cable: stap 4, afbeelding 1 van 1
    • Move aside the power adapter-port cable from the screws.
  5. Dell Inspiron 15R 5521 Display Assembly Replacement, Remove the Screws: stap 5, afbeelding 1 van 1
    • Remove the screws that secure the display assembly to the computer base.
  6. Dell Inspiron 15R 5521 Display Assembly Replacement, Lift the Display Assembly: stap 6, afbeelding 1 van 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 15R 5521 Display Assembly Replacement, Placing the Display Assembly: stap 7, afbeelding 1 van 1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  8. Dell Inspiron 15R 5521 Display Assembly Replacement, Replace the Screws: stap 8, afbeelding 1 van 1
    • Replace the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 15R 5521 Display Assembly Replacement, Connecting the Cables: stap 9, afbeelding 1 van 1
    • Connect the wireless mini-card cables to the connectors on the wireless mini-card.
  10. Dell Inspiron 15R 5521 Display Assembly Replacement, Connect the Display Cable: stap 10, afbeelding 1 van 1
    • Connect the display cable to the connector on the system board.
  11. Dell Inspiron 15R 5521 Display Assembly Replacement, Adhering the Tape: stap 11, afbeelding 1 van 1
    • Adhere the tape that secures the display cable to the system board.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Terrence15
79.243 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.989 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 658
