Ga door naar hoofdinhoud
Dell Inspiron 1564 RAM Replacement
Wat je nodig hebt
  1. Dell Inspiron 1564 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Dell Inspiron 1564 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Locate the battery latch on the bottom of the computer and slide it to the right.
    • While holding the battery latch, pull the battery away from the device.
  2. Dell Inspiron 1564 RAM Replacement: stap 2, afbeelding 1 van 1
    • With the Phillips #0 screwdriver, loosen the three screws from the cover behind the battery latch.
  3. Dell Inspiron 1564 RAM Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 1564 RAM Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 1564 RAM Replacement: stap 3, afbeelding 3 van 3
    • Locate the RAM on the bottom of the computer.
    • Remove the RAM by gently pulling back the small clips along the side of the RAM, and lifting the RAM upwards so the RAM is now angled.
    • Pull the RAM away from the device.
    • Repeat the actions above for the second stick of RAM.
    • When reinstalling the RAM, put it back in at an angle in the socket, and make sure the RAM is audiblely clicked into place.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 952
