Ga door naar hoofdinhoud
Dell Inspiron 1545 Display Replacement
Wat je nodig hebt
  1. Dell Inspiron 1545 Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Display Replacement: stap 2, afbeelding 1 van 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Display Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Display Replacement, Center Control Cover: stap 4, afbeelding 1 van 1
    • After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
  5. Dell Inspiron 1545 Display Replacement: stap 5, afbeelding 1 van 1
    • Flip the laptop over to the front and open the display as far as possible.
  6. Dell Inspiron 1545 Display Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 1545 Display Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 1545 Display Replacement: stap 6, afbeelding 3 van 3
    • The Center Control Cover is VERY fragile, be careful when using prying tools.
    • Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
    • Carefully lift the Center Control Cover away from the laptop.
  7. Dell Inspiron 1545 Display Replacement, Keyboard: stap 7, afbeelding 1 van 1
    • Remove the two screws (5mm Phillips #1) at the top of the keyboard.
  8. Dell Inspiron 1545 Display Replacement: stap 8, afbeelding 1 van 1
    • Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
    • Do not pull hard on the keyboard while removing it, you may damage the keyboard or the keyboard connector.
  9. Dell Inspiron 1545 Display Replacement: stap 9, afbeelding 1 van 1
    • Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
    The connector latch is the black piece.
    Maurice Volaski - Antwoord
    Good tip! As shown. flips up and toward user
    Tom Borden - Antwoord
  10. Dell Inspiron 1545 Display Replacement: stap 10, afbeelding 1 van 1
    • Lift the keyboard up and away from the laptop.
  11. Dell Inspiron 1545 Display Replacement, Display: stap 11, afbeelding 1 van 1
    • Remove the two screws (5.5mm, Phillips #1) from the laptop base.
    Uh, how did the back cover end up coming off?
  12. Dell Inspiron 1545 Display Replacement: stap 12, afbeelding 1 van 1
    • Remove black and white wires from the WLAN that lead to the display by pulling straight up.
    • Unwind the wires so they can be freely pulled through in the next step.
  13. Dell Inspiron 1545 Display Replacement: stap 13, afbeelding 1 van 1
    • Turn the laptop over to its standard position.
    • Disconnect the Wed cable and Camera1 cable from the respective Motherboard connectors as marked. Unsecure the wires so they are loose.
    • Pull the black and white wires previously connected to the WLAN through the hole.
  14. Dell Inspiron 1545 Display Replacement: stap 14, afbeelding 1 van 1
    • Remove the Camera1 cable, the Wed cable, and the black and white wires from the routing guides.
    • Remove the four screws (5mm Phillips #1) (two on either side) that secure the display assembly.
  15. Dell Inspiron 1545 Display Replacement: stap 15, afbeelding 1 van 1
    • Lift the display assembly off the computer.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Nathan Lemay
3.112 Reputatie
15 handleidingen geschreven
Cal Poly, Team 9-14, Regan Spring 2014 Lid van Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Leden
3Gids Commentaar
wow that is really good
Mck - Isolutions - Antwoord
AWESOME, but how to know if display is faulty or some issue in the other device causing blank screen
Kumar Bhrigu - Antwoord
put it back toghther, then plug in a external monitor
Feyrowan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 5,790
