Ga door naar hoofdinhoud
Dell Inspiron 1545 Computer Processing Unit Replacement
Wat je nodig hebt
  1. Dell Inspiron 1545 Computer Processing Unit Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before attempting to remove the battery ensure that the laptop is disconnected from all power sources and turned off.
    • Turn the laptop over to its back.
  2. Dell Inspiron 1545 Computer Processing Unit Replacement: stap 2, afbeelding 1 van 1
    • Slide the release latch while simultaneously pulling backwards on the battery.
  3. Dell Inspiron 1545 Computer Processing Unit Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery out of the battery bay.
  4. Dell Inspiron 1545 Computer Processing Unit Replacement, Base Cover: stap 4, afbeelding 1 van 1
    • Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
    • The top 3 screws are "captive" (held in by a retaining ring) and will not come out.
  5. Dell Inspiron 1545 Computer Processing Unit Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 1545 Computer Processing Unit Replacement: stap 5, afbeelding 2 van 2
    • Carefully lift the base cover vertically away from the laptop.
  6. Dell Inspiron 1545 Computer Processing Unit Replacement, CPU Heat Sink: stap 6, afbeelding 1 van 1
    • Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
    • These screws are held in place by a washer so you should not be able to completely remove the screws.
  7. Dell Inspiron 1545 Computer Processing Unit Replacement: stap 7, afbeelding 1 van 1
    • Pull up on the Heat Sink unit to remove it.
  8. Dell Inspiron 1545 Computer Processing Unit Replacement, Computer Processing Unit: stap 8, afbeelding 1 van 1
    • Using a flathead screwdriver, rotate the locking mechanism counterclockwise to the unlocked position.
  9. Dell Inspiron 1545 Computer Processing Unit Replacement: stap 9, afbeelding 1 van 1
    • The CPU is very fragile and has thin pins.
    • Remove the CPU by pulling straight upward and away from the laptop.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Nathan Lemay
3.145 Reputatie
15 handleidingen geschreven
Cal Poly, Team 9-14, Regan Spring 2014 Lid van Cal Poly, Team 9-14, Regan Spring 2014
CPSU-REGAN-S14S9G14
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 3,036
