Ga door naar hoofdinhoud
Dell Inspiron 1525 Upper Case Replacement
Wat je nodig hebt
  1. Dell Inspiron 1525 Upper Case Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Upper Case Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Upper Case Replacement, Central Control Cover: stap 3, afbeelding 1 van 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Upper Case Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Upper Case Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 5, afbeelding 3 van 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
  6. Dell Inspiron 1525 Upper Case Replacement, Keyboard: stap 6, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement, Keyboard: stap 6, afbeelding 2 van 2
    • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
    • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
  7. Dell Inspiron 1525 Upper Case Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 7, afbeelding 2 van 2
    • Use a spudger to gently lift the ribbon cable retaining flap.
    • Disconnect the ribbon cable.
    • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
  8. Dell Inspiron 1525 Upper Case Replacement, Bottom Cover: stap 8, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement, Bottom Cover: stap 8, afbeelding 2 van 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  9. Dell Inspiron 1525 Upper Case Replacement, Display Assembly: stap 9, afbeelding 1 van 3 Dell Inspiron 1525 Upper Case Replacement, Display Assembly: stap 9, afbeelding 2 van 3 Dell Inspiron 1525 Upper Case Replacement, Display Assembly: stap 9, afbeelding 3 van 3
    • Disconnect the five antennas from their respective cards.
    • De-route the antennas from their routing retainers.
  10. Dell Inspiron 1525 Upper Case Replacement: stap 10, afbeelding 1 van 1
    • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
  11. Dell Inspiron 1525 Upper Case Replacement: stap 11, afbeelding 1 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 11, afbeelding 2 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 11, afbeelding 3 van 3
    • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
    • Carefully release the connector from its retaining tabs.
  12. Dell Inspiron 1525 Upper Case Replacement: stap 12, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 12, afbeelding 2 van 2
    • Push the antenna wires up through their hole in the bottom case half.
    • Release the antennas from their retaining tabs on the upper case.
  13. Dell Inspiron 1525 Upper Case Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 13, afbeelding 2 van 2
    • Disconnect the flat LCD ribbon cable by pulling it up by the tab.
    • Free the ribbon cable from its retaining clips.
  14. Dell Inspiron 1525 Upper Case Replacement: stap 14, afbeelding 1 van 1
    • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
    • Remove the display assembly from the laptop.
  15. Dell Inspiron 1525 Upper Case Replacement, Upper Case: stap 15, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement, Upper Case: stap 15, afbeelding 2 van 2
    • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
    • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
  16. Dell Inspiron 1525 Upper Case Replacement: stap 16, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 16, afbeelding 2 van 2
    • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
    • Pull the ribbon cable out of the connector.
  17. Dell Inspiron 1525 Upper Case Replacement: stap 17, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 17, afbeelding 2 van 2
    • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
    • Disconnect the device status LED ribbon cable.
  18. Dell Inspiron 1525 Upper Case Replacement: stap 18, afbeelding 1 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 18, afbeelding 2 van 3 Dell Inspiron 1525 Upper Case Replacement: stap 18, afbeelding 3 van 3
    • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
    • Use a spudger to unplug the speaker connector at the top center of the laptop.
    • De-route the speaker wires from their retaining tabs.
  19. Dell Inspiron 1525 Upper Case Replacement: stap 19, afbeelding 1 van 2 Dell Inspiron 1525 Upper Case Replacement: stap 19, afbeelding 2 van 2
    • Use the flat end of a spudger to begin lifting the upper case at its front edge.
    • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
Conclusie
7 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 11,857
