Ga door naar hoofdinhoud
Dell Inspiron 1525 Heat Sink Replacement
Wat je nodig hebt
  1. Dell Inspiron 1525 Heat Sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Heat Sink Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 1525 Heat Sink Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: stap 3, afbeelding 1 van 2 Dell Inspiron 1525 Heat Sink Replacement, Bottom Cover: stap 3, afbeelding 2 van 2
    • Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
    • The screws may only need to be loosened, as they are generally retained by plastic washers.
    • Remove the bottom panel.
  4. Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 1 van 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 2 van 3 Dell Inspiron 1525 Heat Sink Replacement, Heat Sink: stap 4, afbeelding 3 van 3
    • Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
    • These screws are attached to the heat sink assembly.
    • Gently lift the heat sink from side indicated in the picture.
    • The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
    • Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Conclusie
5 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 7,845
