Inleiding
Use this guide to help you replace the heat sink in a Dell Inspirion 1525.
Wat je nodig hebt
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
Gently lift the heat sink from side indicated in the picture.
5 andere personen hebben deze handleiding voltooid.
