Inleiding
Use this guide to help you replace the ExpressCard Cage in a Dell Inspiron 1525.
Wat je nodig hebt
Remove the two 4.00 mm Phillips #1 screws from the battery tray.
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Remove/loosen the eight 4.80 mm Phillips #1 screws securing the bottom panel.
The screws may only need to be loosened, as they are generally retained by plastic washers.
Remove the bottom panel.
Disconnect the five antennas from their respective cards.
De-route the antennas from their routing retainers.
Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
Lift the ExpressCard cage out of its connector.
Één andere persoon heeft deze handleiding voltooid.
