Ga door naar hoofdinhoud
Dell Inspiron 1525 Central Control Cover Replacement
Wat je nodig hebt
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 1525 Central Control Cover Replacement: stap 2, afbeelding 2 van 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: stap 3, afbeelding 1 van 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: stap 4, afbeelding 1 van 3 Dell Inspiron 1525 Central Control Cover Replacement: stap 4, afbeelding 2 van 3 Dell Inspiron 1525 Central Control Cover Replacement: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 1525 Central Control Cover Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 1525 Central Control Cover Replacement: stap 5, afbeelding 3 van 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Conclusie
4 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 22
Altijd: 3,648
