Inleiding
In this guide we will be showing you how to replace the battery on your Dell Inspiron 1525. You don't need any tools for this process.
Flip the computer upside down and locate the battery release switch.
  • Flip the computer upside down and locate the battery release switch.
  • Remember to disconnect any and all power sources when working on any electronic device to prevent damage.
Voeg opmerking toe
Slide and hold the switch away from the lock symbol to release the battery lock.
  • Slide and hold the switch away from the lock symbol to release the battery lock.
Voeg opmerking toe
Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
  • Grip the battery and gently pull it away from the rest of the device. You can now let go of the battery release switch and let it return to its original position.
Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Phil Hopkins
308 reputatie
1 Handleiding geschreven
Cal Poly, Team 23-101, Johann Spring 2010 Lid van Cal Poly, Team 23-101, Johann Spring 2010
CPSU-JOHANN-S10S23G101
2 Leden
1 handleiding geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 12
Altijd: 4,436
