Ga door naar hoofdinhoud
Dell Inspiron 1521 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 1521 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Keyboard Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 2, afbeelding 3 van 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 1521 Keyboard Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Keyboard Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Keyboard Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 1521 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nikolaus Powell
426 Reputatie
3 handleidingen geschreven
Cal Poly, Team 15-47, Forte Fall 2012 Lid van Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 2,078
