Ga door naar hoofdinhoud
Dell Inspiron 1521 Central Processing Unit (CPU) Replacement
Wat je nodig hebt
  1. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Battery: stap 1, afbeelding 1 van 1
    • Rotate the laptop so its bottom is facing up.
  2. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 2, afbeelding 3 van 3
    • Identify the lock mechanisms holding the battery in place.
    • Slide each button outward with your fingers to disengage the battery.
    • Pull the battery off with your hand to separate it from the laptop.
  3. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Keyboard: stap 3, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Keyboard: stap 3, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Keyboard: stap 3, afbeelding 3 van 3
    • Find the two small indentations of the sides of the panel covering the power button.
    • Pry up both sides of the panel by sticking the plastic opener tool in each indentation and prying up.
  4. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 4, afbeelding 1 van 1
    • Now that the panel is loose simply pull the panel off with your hand.
  5. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 5, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 5, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 5, afbeelding 3 van 3
    • Locate the two 5 mm Phillips #1 screws holding down the keyboard that were underneath the panel.
    • Remove these screws with a Phillips #1 screwdriver.
    • With the screws removed pull the keyboard up with your hand.
  6. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 6, afbeelding 3 van 3
    • Locate the connector that links the keyboard to the laptop.
    • Gently pull the connector toward the screen of the laptop with your figers to disconnect it.
  7. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Display Assembly: stap 7, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Display Assembly: stap 7, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Display Assembly: stap 7, afbeelding 3 van 3
    • Locate the two Phillips #1 screws holding the Wireless Local Area Network (WLAN) panel in place.
    • Remove these two screws with a Phillips #1 screwdriver.
    • Remove the WLAN panel by pulling it up with your hand.
  8. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the black and white wires attached to the WLAN card by pulling up on the connectors with your fingers.
    • During reassembly, the black and white wires reconnect to the WLAN card near the black and white triangles, respectively.
    • Remove the remaining wires from their protective sleeve by hand.
    • The wires in the sleeve are only used in other Dell laptop models. During reassembly they do not connect to anything so just place them back into the sleeve.
  9. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 9, afbeelding 2 van 2
    • Pull the wires that you disconnected in the previous step through the hole in the top of the laptop.
  10. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 10, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 10, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 10, afbeelding 3 van 3
    • Detach the Phillips #1 grounding screw with a Phillips #1 screwdriver.
    • Disconnect the display cable by pulling up on the rectangular tab with your fingers.
  11. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 11, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 11, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 11, afbeelding 3 van 3
    • When disconnecting the camera/microphone cable, pull up by the white plug. Pulling on the cable itself can damage it.
    • Disconnect the camera/microphone cable by prying it upward with the plastic opener tool.
    • Separate the camera/microphone cable from the case by pulling it up with your fingers.
  12. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 12, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 12, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 12, afbeelding 3 van 3
    • Remove the two 10 mm Phillips #1 screws from the bottom of the laptop that attach the lid assembly to the laptop with a Phillips #1 screwdriver.
    • Remove the two 10 mm Phillips #1 screws from the back of the laptop that also attach the lid assembly to the laptop with a Phillips #1 screwdriver.
  13. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 13, afbeelding 1 van 2 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 13, afbeelding 2 van 2
    • There is a risk of dropping the lid or base of the laptop, or damaging cables. Make sure no cables are still attached.
    • Remove the lid by pulling it up from the base of the laptop with both hands.
  14. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Bottom Panel: stap 14, afbeelding 1 van 2 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Bottom Panel: stap 14, afbeelding 2 van 2
    • Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
    • Remove the thirteen indicated screws with a Phillips #1 screwdriver.
    • With the screws removed you can now remove the panel underneath keyboard.
  15. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Central Processing Unit (CPU): stap 15, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Central Processing Unit (CPU): stap 15, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement, Central Processing Unit (CPU): stap 15, afbeelding 3 van 3
    • Locate the four 4 mm Phillips #1 screws securing the panel underneath the keyboard.
    • Remove the four screws with a Phillips #1 screwdriver.
    • Gently lift panel underneath the keyboard with both hands, thus removing it from the laptop.
  16. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 16, afbeelding 1 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 16, afbeelding 2 van 3 Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 16, afbeelding 3 van 3
    • The screws that hold the CPU heat sink in place are attached to the heat sink with springs and washers. They should only be loosened enough to detach the heat sink. Do not try to remove the screws from the heat sink itself.
    • Locate the four Phillips #1 screws securing the heatsink over the CPU.
    • Remove the screws securing the heat sink with a Phillips #1 screwdriver.
    • Lift the heat sink off of the CPU upwards with your fingers.
  17. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 17, afbeelding 1 van 1
    • Remove the one Flathead #2.5 screw securing the CPU with a Flathead #2.5 screwdriver.
  18. Dell Inspiron 1521 Central Processing Unit (CPU) Replacement: stap 18, afbeelding 1 van 1
    • The CPU has many small pins on the underside which can easily be bent. Bending CPU pins will permanently damage the CPU. Handle with extreme care to avoid bending any pins.
    • Carefully lift the CPU off of the board with your fingers.
    • If you want to add a new CPU don't forget to clean and apply fresh thermal paste to the new processor.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Joana Sanchez
59 Reputatie
1 Handleiding geschreven
Cal Poly, Team 15-47, Forte Fall 2012 Lid van Cal Poly, Team 15-47, Forte Fall 2012
CPSU-FORTE-F12S15G47
5 Leden
9 handleidingen geschreven
3 opmerkingen
Unlocked password
Phende - Antwoord
Dell Insprion 5720. Laptop / Help ASP !!
Phende - Antwoord
These pictures are upside down a lot of the times, can’t tell what’s going on
James Bedortha - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 4,302
