Ga door naar hoofdinhoud
Dell Inspiron 15-7567 Wireless Card Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7567 Wireless Card  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off laptop before beginning.
    • Place the laptop upside down on a flat, stable surface.
  2. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-7567 Wireless Card  Replacement: stap 2, afbeelding 2 van 2
    • Remove the 3mm screw in the location shown, using a Phillips #1 screwdriver.
  3. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 3, afbeelding 1 van 1
    • Remove the panel from the sides and pull it out at an angle towards you.
  4. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7567 Wireless Card  Replacement: stap 4, afbeelding 2 van 2
    • Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
  5. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15-7567 Wireless Card  Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the power cord from the battery by using a pair of tweezers, your fingers, or the opening tools from the iFixit pro tech tool kit.
    • Pinch the clips on the left and right side while pulling on the cord at the same time.
  6. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 6, afbeelding 1 van 1
    • Pull the battery towards you.
    • Make sure to pull at an upward angle.
  7. Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: stap 7, afbeelding 1 van 2 Dell Inspiron 15-7567 Wireless Card  Replacement, Wireless Card: stap 7, afbeelding 2 van 2
    • Remove the 3mm screw using the Phillips #0 screwdriver in the location shown.
    • Remove the grey panel as well.
  8. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 8, afbeelding 1 van 1
    • Detach the black and white wires connected to the card by gently lifting up on the wires.
  9. Dell Inspiron 15-7567 Wireless Card  Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 15-7567 Wireless Card  Replacement: stap 9, afbeelding 2 van 2
    • Gently pull the wireless card out at an angle towards you.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 778
