Ga door naar hoofdinhoud
Dell Inspiron 15-7559 Repair Memory Modules Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 2, afbeelding 3 van 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-7559 Repair Memory Modules Replacement: stap 3, afbeelding 3 van 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Popping up the Memory Module: stap 4, afbeelding 1 van 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  5. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: stap 5, afbeelding 1 van 1
    • Slide and remove the memory module from the memory-module slot.
  6. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Align the Notch: stap 6, afbeelding 1 van 1
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  7. Dell Inspiron 15-7559 Repair Memory Modules Replacement, Sliding the Memory Module: stap 7, afbeelding 1 van 1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
Eindstreep
Terrence15
79.309 Reputatie
441 handleidingen geschreven
RampUP America, Inc. Lid van RampUP America, Inc.
Community
42 Leden
1.984 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 1,117
