Ga door naar hoofdinhoud
Dell Inspiron 15-7559 Keyboard Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: stap 1, afbeelding 2 van 3 Dell Inspiron 15-7559 Keyboard Replacement, Keyboard: stap 1, afbeelding 3 van 3
    • Using the flat end of the spudger press in the 5 tabs, located on top of the keyboard, as you use the spudger to pry each section up.
    • After releasing the 5 tabs, slide the opening tool around the top and sides of the keyboard to make sure it is fully released.
  2. Dell Inspiron 15-7559 Keyboard Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-7559 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Now lift the keyboard enough to access the ribbon cables beneath it.
  3. Dell Inspiron 15-7559 Keyboard Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-7559 Keyboard Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-7559 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • For the two ribbon cables connecting the keyboard to the laptop, use your finger to lift the latch up.
    • Once the latch is raised, lift the ribbon cable up and out of the latch.
  4. Dell Inspiron 15-7559 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Now that the keyboard has been fully disconnected from the laptop, lift it off of the device.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Trenton Greevebiester
1.536 Reputatie
6 handleidingen geschreven
UW Tacoma, Team S3-G2, Liner Fall 2017 Lid van UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Leden
9 handleidingen geschreven
2 opmerkingen
How to put it back
Using Name - Antwoord
Do the steps in reverse order, like it says at the end of the tutorial
Arthur Alford -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 42
Altijd: 6,929
