Ga door naar hoofdinhoud
Dell Inspiron 15-7559 Hard Drive Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7559 Hard Drive Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to turn off the device and disconnect the cable could lead to personal injury or device damage.
    • Flip the computer upside down.
  2. Dell Inspiron 15-7559 Hard Drive Replacement: stap 2, afbeelding 1 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 2, afbeelding 2 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove the captive screw located on the top section of the back panel, using a Philips #1 screwdriver.
    • Keep in mind that the screw cannot be fully removed from the panel, even when fully loosened.
  3. Dell Inspiron 15-7559 Hard Drive Replacement: stap 3, afbeelding 1 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 3, afbeelding 2 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Use the blue, plastic opening tool to gently pry a section of the back panel open.
    • Next slide the opening tool around the back panel to disconnect the clips holding the panel in place.
    • After the clips have been disconnected, the back panel can then be easily lifted off the computer.
  4. Dell Inspiron 15-7559 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Locate the hard drive on the bottom right side of the laptop.
  5. Dell Inspiron 15-7559 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15-7559 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the 4 x 2.5mm x 5mm screws, using the Philips #1 screwdriver.
  6. Dell Inspiron 15-7559 Hard Drive Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 15-7559 Hard Drive Replacement: stap 6, afbeelding 3 van 3
    • Using your hands, raise the hard drive far enough to disconnect the cables attached to it.
    • Using your hand grab the black portion connecting the cables to the battery and disconnect it.
    • Do not pull on the cables directly. This would risk damaging them or tearing them from the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Trenton Greevebiester
1.536 Reputatie
6 handleidingen geschreven
UW Tacoma, Team S3-G2, Liner Fall 2017 Lid van UW Tacoma, Team S3-G2, Liner Fall 2017
UWT-LINER-F17S3G2
5 Leden
9 handleidingen geschreven
2 opmerkingen
Is there a step related to removing the hard drive mount? I believe that you’ll need the mount in order to screw a new drive into the system.
David Trang - Antwoord
Are there other options beside the same seagate hard drive? I’m reading on forums that this hard drive is not very reliable. And since mine just completely died after less than 4 years I’m skeptable replacing it with the same exact hard drive?
Tee Rivera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 75
Altijd: 8,825
