Inleiding
If your Dell Inspiron 15-7548 laptop is struggling to process the amount of apps you typically use, upgrading your RAM sticks may be a good option to keep the laptop working smoothly.
Before upgrading your RAM sticks, make sure all your laptop software is up to date. This could be another reason your computer is not operating at peak efficiency.
Before beginning, make sure to power off your laptop completely, and disconnect the laptop from any external power source.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Unscrew the six 2.5x6mm screws and remove them using a Phillips #1 screwdriver.
Loosen the four 2x3mm captive screws at the bottom.
