Ga door naar hoofdinhoud
Dell Inspiron 15-7548 Fan Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7548 Fan Replacement, Back Panel: stap 1, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Remove the six 6 mm screws from the back panel with a Phillips #1 screwdriver.
    • Loosen the four captive screws at the bottom using a Phillips #1 screwdriver.
    • The four screws on the bottom are captive screws and cannot be removed.
  2. Dell Inspiron 15-7548 Fan Replacement: stap 2, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement: stap 2, afbeelding 2 van 2
    • Pry out the back panel using the flat head side of the spudger.
    • Do not insert the spudger more than half an inch when separating the bottom and right side of the back panel.
  3. Dell Inspiron 15-7548 Fan Replacement, Battery: stap 3, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement, Battery: stap 3, afbeelding 2 van 2
    • Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
  4. Dell Inspiron 15-7548 Fan Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 2.5x6mm screws using a Phillips #1 screwdriver.
  5. Dell Inspiron 15-7548 Fan Replacement, Fan: stap 5, afbeelding 1 van 1
    • The two fans are located at the top of the computer.
    • The fan on the left is for the GPU (Graphics processing unit) and the right fan is for the CPU (Central processing unit).
  6. Dell Inspiron 15-7548 Fan Replacement: stap 6, afbeelding 1 van 3 Dell Inspiron 15-7548 Fan Replacement: stap 6, afbeelding 2 van 3 Dell Inspiron 15-7548 Fan Replacement: stap 6, afbeelding 3 van 3
    • To unplug the CPU fan lift the black plastic cutout next to the fan.
    • The connection can be removed by hand or with the plastic spudger.
  7. Dell Inspiron 15-7548 Fan Replacement: stap 7, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement: stap 7, afbeelding 2 van 2
    • Remove the two 2x3mm screws from the fan using the Phillips #1 screwdriver.
    • The unit may now be removed from the board.
    • The black cord running alongside the fan is for the display. Push it aside if it stops you from removing the fan.
  8. Dell Inspiron 15-7548 Fan Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 15-7548 Fan Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 15-7548 Fan Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the unit from the motherboard.
    • It may be easier to disconnect with the spudger tool but it can also be done by hand.
  9. Dell Inspiron 15-7548 Fan Replacement: stap 9, afbeelding 1 van 2 Dell Inspiron 15-7548 Fan Replacement: stap 9, afbeelding 2 van 2
    • The black and white wires need to be unplugged and removed from the tabs on the fan.
    • Use a pair of tweezers to unplug the wires.
    • When reconnecting the wires connect the white to the top plug and the black to the bottom.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 59
Altijd: 2,178
