Inleiding
This guide will walk you through the process of replacing a dead or damaged battery in your Dell Inspiron 15-7548.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Unscrew the six 2.5x6mm screws and remove them using a Phillips #1 screwdriver.
Loosen the four 2x3mm captive screws at the bottom.
Disconnect the battery from the motherboard by pulling the black tab attached to the cable.
