Ga door naar hoofdinhoud
Dell Inspiron 15-7547 LCD Assembly Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7547 LCD Assembly Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 2, afbeelding 1 van 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: stap 3, afbeelding 1 van 2 Dell Inspiron 15-7547 LCD Assembly Replacement, WiFi Card: stap 3, afbeelding 2 van 2
    • Remove the 3.0 mm-long Philips #0 screw at the end of the Wifi-Card
  4. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the Wifi-Card from its socket by pulling away and up from the connector.
  5. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 5, afbeelding 1 van 2 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the white and black cables from the Wifi-Card.
    • Make a note of which wire goes where for reconnecting them to the replacement card.
  6. Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: stap 6, afbeelding 1 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: stap 6, afbeelding 2 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement, LCD Assembly: stap 6, afbeelding 3 van 3
    • Remove the six 7.0 mm-long Philips #0 screws that mount the hinges.
  7. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 7, afbeelding 1 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 7, afbeelding 2 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 7, afbeelding 3 van 3
    • Use a spudger to unlatch and unplug the display cable.
    • There will be a notch on the side of the connector.
  8. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 8, afbeelding 1 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 8, afbeelding 2 van 3 Dell Inspiron 15-7547 LCD Assembly Replacement: stap 8, afbeelding 3 van 3
    • Raise the left and right hinges.
  9. Dell Inspiron 15-7547 LCD Assembly Replacement: stap 9, afbeelding 1 van 1
    • Remove the LCD display assembly from the laptop.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 784
