Ga door naar hoofdinhoud
Dell Inspiron 15-7547 CPU Fan Replacement
Wat je nodig hebt
  1. Dell Inspiron 15-7547 CPU Fan Replacement, Bottom Cover: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Close the display and flip the laptop on its back.
    • Loosen the ten 5.0 mm-long Phillips #0 screws.
    • The four screws marked with orange will remain captive to the cover.
  2. Dell Inspiron 15-7547 CPU Fan Replacement: stap 2, afbeelding 1 van 1
    • Use a spudger to pry up and loosen the back cover.
    • Remove the back cover.
  3. Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: stap 3, afbeelding 1 van 2 Dell Inspiron 15-7547 CPU Fan Replacement, CPU Fan: stap 3, afbeelding 2 van 2
    • Remove the two 5.0 mm-long Philips #0 screws from the fan.
    • The screw marked in orange will remain captive to the fan.
  4. Dell Inspiron 15-7547 CPU Fan Replacement: stap 4, afbeelding 1 van 2 Dell Inspiron 15-7547 CPU Fan Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire that connects the fan to the motherboard. This can be found under the flap directly to the left of the fan.
  5. Dell Inspiron 15-7547 CPU Fan Replacement: stap 5, afbeelding 1 van 1
    • Lift the fan out of the chassis.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 513
